I bought a msd kit and the pro billet distributor has no vacuum advance but my old distributor has one is this a problem?I have a 79 camaro 350 motor.:confused:
I am a big advocate of vacuum advance. All but the most radical motors will benefit from it. Vacuum advance helps raise idle vacuum, improve idle quality and improves off-idle response.
its sounds like you bought one with a mechanical advance, block off your carb port and set your distributor to correct timing
