While I had my Muncie out for some Clutch work, I decided to replace the gaskets in my tranny and basically just take a good look in there to make sure that everything is all right. When I took the front bearing retainer off, I noticed that the bearing did not fit tight in the case at all. I can rotate the bearing (the outer race, not the inner) freely and I think that it has been rotating during operation. Should the bearing fit like this? Does the bearing retainer hold everything in place, or is my case just shot?
The bearing retainer holds it in place,
Try pushing the race up and down, left to right, if you can see movement, and a gap between to outer race and the case then yes it sounds like the bearing rotated and the case is toast.
Yes, I can get side to side movement. I figured the case was gone. I don't suppose that there is anything that can be done to correct this?
Yes replace it.
http://www.gearzone.net/case.html
The case is the weak part of the muncie series trans. By using a super case and a cast iron mid plate you can prevenent premature failure of your good tranny.
Just for information purposes you can get a new super case, a NEW set of M-20 gears cut on the M-22 angle and an iron mid plate for about $900.00 That and your "parts" m-20 and a gasket set you can have a bullet prof ( well almost ) set up . $900 seem like a bunck of money? What would it cost to build up a rear or slap on a set of aluminum heads?
If you can build a motor you can build a muncie with only one special tool, a thin wrench for the front retaining nut.
Or, it you want to rebuild I have a M-20 case leftover from when I had an Autogear M-22 built.
Rick Dorion
69 RS Conv,355,Autogear M22,4.10's and I don't worry about stone chips ( yet ).
Rick, you have mail.
69 Camaro
400 Small Block
Trick Flow Heads
Comp 282S solid cam
Performer RPM intake
750 CFM Holley
and a Muncie four speed
Pics of My Car
I just picked up a new used case. The difference is amazing. The front bearing fits like it should now.
It looks like someone dipped my old case in acid or went crazy with a sand blaster because it looks like the hole that the front bearing fits in was eaten away, not worn away. This thing should finally be right now.
69 Camaro
400 Small Block
Trick Flow Heads
Comp 282S solid cam
750 CFM Holley
Pics of My Car
