I need some help,I have a muncie 4 speed with with the large main shaft and the 3 hole tailshaft(397864).The tranny is a 1970 (3925661)I need to know if anyone can help me find what kit I need to use to mount my hurst comp plus shifter # 3914340 in a 1969 Camaro with the factory console.I know someone out there has done this setup before me.Thanks for your help.
Hurst has an excellent parts manual, if you can get a look at one you will find that it lists just about every thing you would need.
I purchased a mounting bracket from Hurst it bolts under the tranni mount, and has a u-bolt that goes around the tail stock. it is for a 68 with console.
Hi Rob,
I have that mount and it doesn't line up.I am looking for a plate with the GM number of 9785269.I think this might work or 9791899.I haven't had a chance to find a Hurst manual yet to check on other numbers .Thank you for your help John
