1 - 18 of 18 Posts
Date pic was taken and where?
Congrats on the winnings.
Nice picture/stance.
NHRA Division 7 ET Class
A Big Congratulations !
Your website is an excellent time capsule of drag racing’s Golden Era.
“We run a 383 sbc, flat tappet cam, Dart Iron Eagle Heads, Ross Pistons, Mikes Trans Glide , with an Alky Carb. We have ran a best of 10.07 at 131.78 m.p.h. at Fomoso in Bakersfield,Ca. The car is all steel and original glass and weighs 3125 lbs. with driver.”
Any chance you have an in car video of your 383 in action ?
Sub frame connectors ?
Rear end, 12 bolt ? Ratio ?
Fuel pump ?
What rpm off line, thru The traps?
What is advantage of alky carb ?
Thanks !
ET7333,
Your launch looks just like a Bill Jenkins car. 👍
Any info you can share about 383
would be helpful.
Rod length
Cam specs
Thanks again.
Discussion Starter · #11 ·
Fuel pump ?
Thanks !
Moser 12 bolt 4:56 gear with a spool-3600 on rpm on starting line-7000 in lites-Magnafuel 500 fuel pump-welded in frame connectors-Alky is very consistent and cheap.
Wheel Tire Automotive tire Motor vehicle Automotive lighting
1 - 18 of 18 Posts
