I need encouragement.
I'm in the process of putting OER "OE" type gauges back in the dash and console. I bought a new tach and speedo. I have had them put in a new housing and installed in the dash. The tach reads about 1500 rpm too high at idle for some reason. I'm using a MSD #8360 dist. with a std. type red blaster coil. Any ideas?
With the console gauges the back light bulb holders won't stay in place. The fuel gauge only reads 3/4 full when the tank is full and the oil pressure gauge is stuck at 20lbs.
The previously installed Moon hot rod style gauges all worked fine. I just could not read them at a glance. So I when back to stock.
So far I'm out $500 in labor.
Helpful hints would be much appreciated,
Thanks,
Thanks,
