This was originally bright blue deluxe interior and will be when complete. So, speaker cover colors match the dash? Great! What about the rear speaker covers? Same thing?
This was originally bright blue deluxe interior and will be when complete. So, speaker cover colors match the dash? Great! What about the rear speaker covers? Same thing?Kick panels should be the carpet/dash color/console colors. What’s the interior code?
The speaker cover is already part of the dash isn’t it? I can’t say for certain about the rears, but the reproduction ones I got are a silver/bare steel color. Try hereThis was originally bright blue deluxe interior and will be when complete. So, speaker cover colors match the dash? Great! What about the rear speaker covers? Same thing?
I think I can contribute and add my experience here.This was originally bright blue deluxe interior and will be when complete. So, speaker cover colors match the dash? Great! What about the rear speaker covers? Same thing?
I appreciate the information. I am only dying the kick panels and a few vinyl components. The rest are bright blue.I think I can contribute and add my experience here.
I had a original blue interior that I changed black. My original kick panels were blue.
I have painted my kick panels. I think I really cared about the plastic prep and did things correctly. I used the right primer and only on very well degreased clean surface.
Now the paint is moving away at the contact with the door panel. This is on both DS and PS doors.
The door panel is sticking on the plastic kick off paned part , on that edge.
WIth the previous door panels there was also a contact at that place.
Now that I know this, with painted panels, I would check fitment first and reshape the door panel so that the contact is not present.
Don't know if I am the only one here to have this problem...
Clean well, use adpro (adhesio9n promotor) and then apply the color. I never had a failure and I've changed colors on many vehicles. Factory interior colors did not match one another exactly. Kicks were injected color molded vs any painted surface. I owned a bright blue 67 gut and that's the way it was. I do not know who you are using for an interior vinyl product source.I appreciate the information. I am only dying the kick panels and a few vinyl components. The rest are bright blue.
Thanks. I used the adpro and applied the dye. The kick panels look quite good now. I will add pics tonight for this, the steering column rebuild and the electrical RS motor rebuild.Clean well, use adpro (adhesio9n promotor) and then apply the color. I never had a failure and I've changed colors on many vehicles. Factory interior colors did not match one another exactly. Kicks were injected color molded vs any painted surface. I owned a bright blue 67 gut and that's the way it was. I do not know who you are using for an interior vinyl product source.
What product and company did you use for the color?Thanks. I used the adpro and applied the dye. The kick panels look quite good now. I will add pics tonight for this, the steering column rebuild and the electrical RS motor rebuild.
SEM flexible coatingsWhat product and company did you use for the color?
What’s the consensus on the rear speaker grills? Interior color painted?Here are the last of the parts needing to be sealed and painted.
note that the kick panel speaker covers are notched. I think this was done to leave room for the parking brake pedal travel.
I know the park brake was partially dipped. I’m thinking of applying a coating that will create a metal oxide layer. Then spray the lower portion with sealer. View attachment 307072
Interior color Matte like top of dash. Painting them right now.What’s the consensus on the rear speaker grills? Interior color painted?
Actually the dash top was zero gloss, suede texture. Gloss levels fall into ranges. Matte being less glossy than satin.Interior color Matte like top of dash. Painting them right now.
I just kept adding flattener until the egg shell disappeared. The ratio using the PPG product was about 1 part color to 1.6 part flattener.Actually the dash top was zero gloss, suede texture. Gloss levels fall into ranges. Matte being less glossy than satin.
I could not find the post but do you gave a 68 ashtray instead of a 67?
So, the top of the dash And the speaker covers get FLAT color corresponding to the interior code of the car.I just kept adding flattener until the egg shell disappeared. The ratio using the PPG product was about 1 part color to 1.6 part flattener.
The DX 685 data sheet called for 1:1 to get Flat but that produced an eggshell result.
1.6 to one provided flat results. I tried buying the PPG additive for the suede texture but it was discontinued.
