is it this part?....the dust boot?
OER 5638487 68-69 Camaro Rally Sport,Headlight Door Actuator Boot | eBay
is it this part?....the dust boot?Anyone know where to buy the dust shields that go over the power headlamp electric motors? I can’t find the ones we took off the car.
wrong boot. I need the shield that goes over the electric motor.is it this part?....the dust boot?
That will help. Original screws were dipped in a wax-like coating to seal the threads. I had some but sold many.I agree with that process. We just forgot about them. We did fill the holes with a clear coat/base coat mixture. But, not nearly as good as drilling before paint.
I have the wax tipped screws as well.That will help. Original screws were dipped in a wax-like coating to seal the threads. I had some but sold many.
My buddy Rick had a dented upper grille and is sending me a few clips.
I only showed it disassembled. It’s a pretty straight forward process to remove, clean and reassemble. I have 5 or 6 motors and can show the order if you need to see it.Did I miss it or did you have pictures of the motor gear build?
You'll thank yourself if you install the motor/tranny in the subframe and roll the assembly underneath the body. Those valve covers are temporary. Also very easy to do concentric/parallel bellhousing alignment if not using an automatic.We were getting ready to install the leaf springs but there was only 1 in the box! So, we are going to switch to installing the subframe this weekend.
We just might do that.You'll thank yourself if you install the motor/tranny in the subframe and roll the assembly underneath the body. Those valve covers are temporary. Also very easy to do concentric/parallel bellhousing alignment if not using an automatic.
