I have re-assembled the front end of my '69 after a restoration. The parts in the photos below were in a baggie titled ' Brake line mounting hardware, drivers side'. I took them off but can't remember how they mounted. The two small black pieces are actually rubber grommets that have a hole through the middle about the size of the brake line. Any suggestions? Possibly in the assembly manual? Thanks for any help.
Automotive design Tool Tints and shades Wood Metal
Font Auto part Plastic Automotive design Fashion accessory
Brake line clamps that hold the lines that go down from the master cylinder by the driver's front wheel/frame area. Should have a decent size rubber grommet to keep them secure in the D shaped clamp.
It is the drivers side brake line stand for the brake lines.
In the AIM look at section UPC5/B1. Stand is #12 3958443 bracket, which is bolted to the subframe. Then the 2 split rubber "grommets" are wrapped around the brake lines. Then the large curved bracket #10 "clip" 3952757 captures the rubber grommets and attaches to the stand with the bolt. Shown in View B
Do you have front drum or disc brakes? From your picture the stand looks like front drum brakes. The disc brake stand is different.
Discussion Starter · #5 ·
It was a drum brake car converted to front disc brakes
Discussion Starter · #6 ·
Got it all back in. Thanks guys
