O.K.
I've put this 327 in my 67 but I don't know the cam spec's(big) .I set the valves at .020(solids) when I put a light on it 8-10 degrees is to much and it barks when you try to start it ,if I back off the timing until it starts good (off the tab retarded).then it back fires though the exhaust every time you get off the gas . runs better when it's avd.(hard to start),but still don't have much power in 2nd,3rd,and 4th.
BTW it's 327 11:1 small valve heads(441's)performer in take,holley 600 vac sec,accell hei dist .m21 4 spd.3.08(?)peg leg 10 bolt.
runs at about 210 degrees.
maybe I should just buy a new cam with spec's???????????????????????
stock? 67
hidden 69
stock? 67
hidden 69
