I have low mile engine that has very light bearing wear on a main. All others are perfect on cap side so far.
Anyway looking for quick fix. I do not know if undersize or ?? Without measuring anybody who rebuilds engines know this cap id
DAB
B201 CAPL
6-31 DA49
Any help would be appreciated. I just want to clean up and reinstall.
thanks
Brian,
I can probably cross the number in the AM at teh shop but it will not tell me if it is undersize or not. The numbers are all the same, undersize or not. You need to measure the thickness of the bearing or the size of the crankshaft to see what bearing you need. Most bearings have the undersize "printed" or "stamped" on them.
Thanks and yes most quality bearings have id stamped on them but who knows what these are. Doesn't matter at this point they all the piston 1/2's on the rods are the same way.
So much for a budget build... somehow that never works for me.
