I am adding a new 4 wheel power disc brake setup to my 69 Camaro. The car currently has power front disc brakes. My question is what will I need to add the power front disc brakes from my 69 camaro to a 69 Nova that is 4 wheel drum manual brakes? I need to reuse my 69 camaro steering arms for the new brakes, will the 69 nova steering arms fit the front power disc brakes that were on the 69 camaro? I believe that everything else will be a direct bolt on, such as the spindles, lines, power and master cylinder, prop valve, is this correct? Anything else that I will need to know about the install? Any other parts I will need? Thanks
