What's up guys I converted my 69 camaro to HEI. Where can I get the adapter that goes to the "BAT" and "TACH" pins. It looks like a special adapter, went to a couple auto stores but no one has it, everyone tells me to go to the junk yards. What do you guys think.
Manny
Wickdracer, Jegs has them, but you can use a regular spade wire terminal and just push them on. Make sure you replace the restor wire or you will not get 12 volts to the HEI. The terminal maybe hard to get on, put they will work and if you want to replace them later with the adapters your car is up and running. Good luck Jerry
My car is running now and I'm getting 12volts. The only problem is that it keeps coming off. Want to make sure wirings stay in place. Thanks bro I found it, you guys are the best.
Manny
