They look like flat tops with some really big valve reliefs. Definetly not domed pistons. Domed pistons have a part that sticks up in the middle that would fill space inside the combustion chamber. You might want to CC the piston valve reliefs or the piston in the hole at TDC to be able to calculate your compression ratio.
Kent
67 SS 427
Kent
67 SS 427
