when i turn the key all the way it wont start then move it down a cm it will start then let go it dies out what is it???????? please help me.
pls clarify what you mean by move it down a cm. Are you wiggling the key or what ? ... Also, I read your other post... Using punctuation will make your posts easier to read and understand .... This is a 91 Camaro, right ??? When the car shuts back off, does it die instantly, or, does it struggle and die ??
I think you answered your own question. It sounds like a bad ignition switch.
