Anyone have any luck on where to find these? I can't seem to find them anywhere.
I need the factory style master switch connector for the front driver door and the 3 single switches for the rear 1/4's and passenger door.
I am striking out and can't find them anyone.
Anyone have any idea on a direction to point me?
Thanks!!!
Single window switch connectors are available at Lectric Limited and AAW - Factoryfit.com makes the harnesses so you can replace the switch part of the main drivers side, or just remove the connector if your wiring is intact.
Under repair parts http://www.lectriclimited.com/repair_components.htm
Factory for from AAW for the full new harness.
Thanks.
Do you know where I might be able to find the connector for the driver master switch? That is the one I can't find anywhere.
I am striking out bad
If it is a true GM switch you can buy the drivers harness from American Auto Wire on the http://Factoryfit.com website. You can either remove the connector and put it on your existing harness or pull the drivers side loop from the door and use the new.
