1967 Camaro RS/SS, 383 cu. in., 5-speed Tremec, 3:73 Posi.
I have a 1967 Camaro RS/SS, 383 stroker, AC, manual tranny, Be Cool radiator. 23" shroud (3893814), short water pump and need some advice on choosing a fan. I live in Texas and the summers can get hot, when driving the temp. is good, if it sits at idle for awhile the temp. will get up and over 220 degrees, timing, carb., radiator are in great shape and the current fan sits half in half out of the shroud. I am changing from the fixed fan to a clutch fan. I am going to purchase the Hayden 2747 fan clutch, important areas to note is the fan bolt circle pattern which is 3.25", the mounting diameter for a fan is 2.59". I have narrowed my fan choice down to the Goodmark GMK4012312681 and the Dynacorn M1017. I believe both fans will fit the Hayden fan clutch 2747.
Hopefully, my fellow enthusiast can help me chose a good fan. Has anyone had experience with either of the two fans I mentioned or any other fan that fits the Hayden 2747 fan clutch and can offer any positive/negative advice? Classic Industries fan 3947772 is great but the fan bolt pattern is 3.0" and I need a bolt pattern of 3.25" Any help and advice is greatly appreciated, Thank you.
