1 - 20 of 22 Posts
I know the title is dumb but I can fix most anything on older cars but I can't diagnose things. So, I just replaced the intake manifold and carb and can't get the engine to run. It has msd distributor and I'm getting spark and gas. I did preliminary timing by turning on the key, putting on the timing light, and turning the dizzy to see where is sparks #1 cylinder. But when I try to start the car is backfires either thru the carb or exhaust. I then move the dizzy maybe 5 degrees and try again. I've moved that dang thing up to 1/4 turn both directions until I literally run the battery down to where it won't crank anymore. I'm out in the country so don't have any help, just by myself. Could anybody give me some direction on how to get the timing close enough to at least start and run, then I can make refinements. I know this is very basic and I feel dumb but don't want to damage anything by continuing to have the engine backfire. Thanks.... And Happy Sunday..
Charge your battery. While it's charging click the link in my signature for how to install a distributor. It's a 2 part video, click "back" after the first 4 minute one plays.
When you drop the dist have your balancer on about 10-12°
Re: Need help please, to get my engine running - Thanks Tim
Thanks Tim. What I've done is pull all plugs, manually turn engine overto find TDC #1. Note position of rotor pointing to #1 plug wire. Make sure firing order is right. Try to start, sputter, backfire, etc. Advance maybe 5 degrees, try again, sputter, backfire, etc. Basically, it won't start and run so I can get out and begin slightly turning the dizzy to smoothen things out. Engine ran perfect before new manifold and carb. This just has to be something I'm not doing or I'm doing wrong. Thanks again Tim....
I forgot to say thanks much for steering me to your videos. Oh, and I'd started with balancer at about 8 degrees. I'm going to pull all the plugs again, get TDC, place dizzy again, and double check firing order. I've got to have something off. Thanks again Tim, your help is very much appreciated....
Are you sure your on compression stroke. Pull #1 plug and have someone bump engine while you have you finger or thumb over plug hole. Wait till you feel you finger getting pressure on it (trying to blow it off). Then manually move balancer to TDC or 10-12deg BTDC. See where your rotor is. If thats all good, double check your plug wires to make sure you have them attched in the right order. I know this sounds basic, but I just made the same mistake the other day.
I'm going back out shortly, will do everything suggested, insuring compression stroke, manually set balancer to about 12 degrees BTDC, correctly align dizzy, check all plug wires going to right plugs, will post results. Damn, this has got to work, simple stuff. Thanks guys.....
I bet your 180* and 6 is firing when 1 should be.
I have got about a half dozen engines running because of this same problem, the distibutor is in wrong!!!!! You can try the finger over the hole trick but sometimes it can be hard to tell. I think the best way to fird TDC is to remove the drivers valve cover and watch the intake valve on the #1 cylinder. Watch it open and then close, once it closes, the next time the timing mark comes around then line it up with 0 and you are at TDC. Then mark the #1 post position on the distributor body and put it in until the mark lines up with the tip of the rotor. Then I alway just slightly turn the distributor housing the opposite direction of rotot rotation to advance it a little. Fire it up and set the timing!
Discussion Starter #11
Nede Help Please, Get Engine Running, Another Question
One more thing. Should I unplug the vaccuum advance to the dizzy or doesn't that make enought difference to matter? If so, do I plug it? My biggest problem has been that I can't get the engine to run well enough so I can get out of the car and under the hood to move the dizzy to where the engine runs well. Being by yourself makes things a bit more difficult but I can do this (I think). Thanks everybody...
Re: Nede Help Please, Get Engine Running, Another Question
Two choices=get a helper or crank the idle speed screw in. Personally I prefer the helper route so I can watch things just in case...You can plug the vacuum in since right now your main concern is the break-in.
Make sure you have the vacuum advance canister positioned so you have adjustment room before it hits the valve cover or intake manifold. This theory caused a big argument awhile back but I know it can happen because I have done it.
Discussion Starter #14
Thanks guys. I've got an hour or so's worth stuff to try. Bet this sucker starts when I make sure I've got everything right.....
Discussion Starter #15
Thanks deerhunter. I'll crank the idle screw in a turn or maybe turn and a half. I never thought bout that but seems obvious that it would keep the engine running (idling) better cause at higher rpm....
One thing I have seen is guys putting the plug wires in the right sequence but going the wrong way around the cap. The engine will not start but it will back-fire up the carb or out the exhaust.
If you haven't got your timing set yet, you want the vacuum advance disconnected and plugged until you get the initial timing set. Especially if you have it set to manifold vacuum.
I watched the video of the guy putting in the distributor and it is not good. I would be nide if he talked!
Why? I know everybody is going to post their own recipe:).
Besides, you wouldn't like my Okie drawl.:D
Edit, Dennis would yank the link if I talked. I'm oilfield and I'd be cussin too much.
What's to say: engine runs,shut it off, pull the dist, pull the plug and stick your stinkin thumb over the hole, bump it til it compresses, position it at 10-12°, drop the dist at the #1 lug minus rotational influence, bump the starter and the dist falls in, stick your thumb over the plug hole again and verify you are on compression then put it at 10-12 again and spin the dist until it lines up with the lug and then tighten it down, put the cap on and start the damthing. Takes longer to type this than it does to watch the videos. Sorry it's a 2 part video guys:sad:
Hay, we could hire me a narrator babe for my next how to video. Cumming soon, how to degree a cam with a narrator babe:D.psst Dub, with both hands then:D
1 - 20 of 22 Posts
