I have a 67 SS without A/C and I'm currently trying to remove the drivers side kick panel. I can't undo the top screw on the kickpanel because the parking break assembly is in the way. How do I get it out? Also after I take the screw out I won't be able to pull the panel all the way off because it looks like the parking break pedal will hold me up again. Please guide me through this. Thanks.
Phil
67 Camaro SS 350
Thanks alot for your help. The two bolts you're talking about are rught below the master cylinder and to the right correct? I'll give it a try.
