1 - 15 of 15 Posts
Brett - Leander, Texas 1969 SS396
I have a new setup and I am having a problem locating a lower radiator hose that will fit or that I can modify. I used to have a long water pump setup on my 396 and the water pump had a 1-1/2 or 1-3/4 connection on it. Now that I installed a CVF Racing Serpentine belt setup. The water pump that came with it is a short water pump with a 2" connection. I went to AutoZone and grabbed one I thought would fit, but the length coming off of the W/P was too long and I cant cut it because I would be cutting off the 2" molded shape. So I ordered one off fleabay and it is a P/N RHK215. Funny thing is it states it is a "Lower Radiator Hose-BBV8", but the description on the GM Restoration Parts sticker it says; "Radiator Hose Kit-Upper" I have the same problem with it- It is too long on the side with the 2" molded opening and I can't cut it because I would be cutting off the 2" part.
Anyone out there have a part number I can order or a particular one listed that will fit the 2" water pump, but is short enough to make the turn into the radiator? It looks like the radiator end is 1-3/4-1/7/8.
Thanks!
Brett......
The new Serpentine set up looks cleaner. Even though it moves the alternator up higher, it moves the A/C compressor over to the passenger side, which shortens the hoses a bunch. The top is before and the lower is current. I have some nicer valve covers that I need to machine the fins before I can put them on.
you can cut out a section of the part of hose that is the smaller diameter and use a metal sleeve of that size to splice in if you can't find a "one piece" hose that fits your custom application
Many time this is an issue as there are no part #s because every set up is different.
I bend up a coat hanger to represent the hose and the local Oreilly and Carquest store let me go behind the counter to match my wires to the hoses on the wall. Sometimes you get lucky and find the perfect hose. Other times you find one that requires cutting the needed section out of a longer hose.
Reactions: HawkX66
Yes John, this is what I was going to do when I got out this morning, but SoCal805's idea prompted me to go onto the Summit website and I see that there are some adapters that I was unaware of. I found one that might enable me to use my old hose as it reduces a 2" down. I do have some options so far. I was able to go "Backstage" at Oreily's looking for a belt a while back so I'll go there this morning.
Thanks!
Brett.....
Yes, I like your idea and will probably do that if my treasure hunt this morning at OReilly's or at NAPA is unsuccessful.
Brett.....
Discussion Starter #9
OP
Obviously you want to find a hose that fits but if you hit the wall the "metal tube splice" type solution is done often. Even using two donor hoses that have no application to your set up but have the right bend/size for one end while another hose section fits the other end leaving you to "bridge" them together with a metal pipe sleeve and clamps. You likely have seen a few cars with this kind of plumbing
Good luck on finding something. Who knows maybe a 2003 Suburu lower hose and a Miata upper cut spliced...(joking about car model)
NAPA, back when auto parts were looked up from huge catalogs on counter, the guy let me look through them until I found something to fix a similar issue on another car. I bought 2 of those so I would not have to do it again later
Discussion Starter #11
The Gates catalog was really helpful. I picked five that looked like they would work, wrote down the part numbers, Went to Oreily's, he had none of them in stock-had to order all of them, which he said he could do and I did not have to pay for them. One was going to be here today. The rest, less one, will be here tomorrow. The last one will be here Tuesday. I will match them up with my "Coat Hanger Gauge". I could just buy them all and the one's that don't fit take them back. I probably won't. I should be able to tell which one will work. I am aware that the splice method is done quite a bit, but I want the fewest failure points as possible if I can. There were some good splice options on Summit, so that is always an option.
Brett....
1969 Camaro Restomod
Brett...
A standard '67-'68 BBC lower hose won't fit? Is the radiator's lower connector angled? Going to be diving into this same deal very shortly.
FYI. Make sure the lower hose you install has a large metal coil/spring inside. If not, the hose will suck shut over time and cause an over heating issue. Your new setup looks nice!
Good Luck
Mike
Discussion Starter #14
Brett...
The standard hose will not work due to the water pump connector being 2" in diameter. most OEM W/Ps are 1-3/4". I think I found a Gates hose. I will know this time tomorrow and let you know with part number.
Brett...
Discussion Starter #15
The hose I found is Gates P/N 21256. It is 2" x 1.75" x 14.9" long. It fit without cutting either end, but it is borderline long, meaning it could probably be cut a little, like 1/4" or so on each end, but I did not cut it.
Brett.....
1 - 15 of 15 Posts
