Properly grounded?
Looking at the pictures…no.Is it possible the alternator has the regulator in it?
Not really. But it’s imperative to have a fully charged battery when troubleshooting the charge system.
You car does NOT have console gauges does it?
Yes, that clip should be bolted to one of the bell housing bolts. Usually near the opposite side of starter , it keeps the wires away from the heat of the exhaust.
Also the ground wire from the battery Usually is bolted to the block near the front. But also there should be a ground strap on the rear of the block that goes to the body.
Your cable should have 2 leads. See pictures. Big cable to the water pump area.On the engine wire harness where does the ground clip attach? And is it for a ground or just to hold something in place?
I think I found on another forum it goes to the bell housing View attachment 293828
Please stop disconnecting the battery with the car running.Thank you! Think we have that all correct. Still cannot get the alternator light to go off. Or keep the car running when we disconnect the neg side of battery. It starts up great. And runs great. Just won't stay running. We are so confused as to what is going on.
Can you explain why? How else do we see if it's not being charged?Please stop disconnecting the battery with the car running.
You answered that question yourself in post #18. It's not charging. At this point just replace the voltage regulator with a solid state as I posted before. It's ~$20. You could take the alternator to a parts house and have it tested just to be sure it's good.Can you explain why? How else do we see if it's not being charged?
Because it does nothing help your cause. You can only troubleshoot with the car in full form. You haven’t answered if the negative cable is correctly attached.Can you explain why? How else do we see if it's not being charged?
So earlier you gave two diff ones. Tuff Stuff 7635 and now solid state. Which is better?You answered that question yourself in post #18. It's not charging. At this point just replace the voltage regulator with a solid state as I posted before. It's ~$20. You could take the alternator to a parts house and have it tested just to be sure it's good.
Yes the neg cable is correctly attached and grounded to the engine block.Because it does nothing help your cause. You can only troubleshoot with the car in full form. You haven’t answered if the negative cable is correctly attached.
The Tuff Stuff is solid state. Here's a link to Amazon.So earlier you gave two diff ones. Tuff Stuff 7635 and now solid state. Which is better?
Thank you!The Tuff Stuff is solid state. Here's a link to Amazon.
Amazon.com: Tuff Stuff Voltage Regulator, Heavy Duty Electronics for Longevity, 1 LB, 7635 : Automotive
Buy Tuff Stuff Voltage Regulator, Heavy Duty Electronics for Longevity, 1 LB, 7635: Voltage Regulators - Amazon.com ✓ FREE DELIVERY possible on eligible purchaseswww.amazon.com
What do you mean?Looking at the pictures…no.
He was wondering if the alternator had an internal regulator. Based on the picture.What do you mean?
