just picked up a 383 stroker from a friend but i want to change the cam to a hydrolic roller and a smoother idle the cam installed now is .507 lift 235in 285 ex the 383 has dart heads with 76cc and 1.5 rockers
around 110-112 LSA, 480 lift, [email protected], 1.6's on the intake
oughta pull plenty hard for you without so much lope.
Try a Competition Magnum Cam and Lifters Set. I have the Magnum 270 Hydraulic Cam and the car pulld hard with a fairly smooth idle.
I went with an Isky roller with the following in my 383:
@050 225INT\225exh w/ 108 lobe .505 lift
depends on how you drive the car. 200CFM is usually the choice.
