gota 69 camaro and running out of rpms at the end of the track, need more what to do ? 358 small block 14/32/15 slicks turbo 350
Not sure. What rpm are you at when you cross the line? If your engine is running well, then I'd agree with 67Rally and gear it down just a little.
There are a lot of gear calculators out there.. find one to help you decide.
The answers above will give you less rpm (and slow you down). You're looking for more rpms to go faster. Without information about your set up, no one can help you.
