Fitting is not cross threaded.
The old rubber lines were visibly leaking and pedal started to get soft. My assumption was the leaking lines were causing the soft, but working, pedal.
Replaced rubber lines and did 4 wheel bleed. Rears never had any bubbles. Fronts had a lot of bubbles and pedal never came back even when bubbles stopped coming out
Maybe the MC was starting to fail same time as rubber lines started leaking...IDK
Given the pedal starts to firm up during bleeding but then goes completely soft I am thinking this is more a MC issue now
The weeping fitting I tightened more as I had removed both new rubber lines to inspect the inner mating surface for the flare end fittings, they looked good. I must have not tightened the DS one enough on the re-install as it had a "slight" build up of fluid on its threads after bleeding attempt. I have since tightened it and pumped brakes and no more weeping from that fitting.
I had initially gotten the large bubbles typical of adding new rubber lines and wheel cylinders which after a few pumps turned into large amounts of fine bubbles that would go away after a few pumps but then return.....and not go away. This is just specific to the front brakes. Rears have always been clean fluid on bleeding, no bubbles.
Looks like a trip to NAPA for a new MC
