Is there one? Using the wiring diagram I found where the Neutral Safety Switch wires should lead into the underdash harness, but there are no wires to the underdash connector at those spots (I was trying bypass the switch temporarily to test my starter).
How does the Neutral Safety Switch work? If not in neutral would there be any power to the starter, i.e., would the starter crank but the engine not fire, or does the switch cut off ignition to the starter?
Thanks in advance for everyones help.
Mike
Mike
