The only one I'm positive about is a console shifted automatic - that is on the shifter itself. The same switch also operates the backup lights.
Column shifted auto - fairly sure it mounts to the top of the column.
Manual trans cars - ???? (probably near the top of the clutch pedal)
On a manual, it's under the dash on the clutch pedal mount area.
Auto column shift, I believe is under dash on the end of the steering column.
Not sure about the console shift location.I would asume under the console someplace.
Or if you just lost it,look on top of the tool box :)
