I recently bought a new edlebrock 750 carb and when I put it on my car and drove it a little bit, I noticed that at low rpm, i.e. 600rpm and I go to accelerate the throttle opens up on it's own. I have to pull the petal up. I put a stronger return spring on but it does it still but not as bad. Is it my motor mounts? or do I need an even stronger spring? What's causing it? Thanks guys
Yup I bet its your motor mount. I had same thing happen, I did burnouts everytime it happened! all the way to the parts store too.
To make sure its a motormount, put it in drive with the hood open, with someone looking in, while holding the brake give it a little gas, But be very careful!
You can buy an improved interlocking type mount for it. 67-68 uses a thinner type than a 69. Energy suspension makes a neat one.
David
David's Homepage
67 RS 327
69 Camaro Vintage Racer
[This message has been edited by davidpozzi (edited 09-06-2000).]
thanks guys I bought the motor mount, I bought the strongest one they had. I'm also going to chain down the driver side of the engine, just to make sure. Thanks for the advice fellas.
twas the motor mount. split clean in half, I put the new one on and chained the S.O.B to the frame. It all better now, thanks for the advice guys.
tim
