1 - 19 of 19 Posts
Hey guys, I finally got around to setting my timing and set it to factory spec which calls for 0 advance, so I set it at 0 degrees.
I start driving it and it knocks under hard accel and when in overdrive at any speed. I tried going with 91 octane (highest I can get) and nothing has changed.
The motor is a rebuilt 383 stroker, mild hyd roller cam (.450", 200 [email protected]"), 9.4 CR, cast pistons, stock 350 heads, Performer intake, Edelbrock headers, Flowmaster muffler....nothing special. I am running all the factory crap, and California emissions except for an EGR valve and CAT.
I can retard the timing and the knock disappears, but that can't be good for mileage or power.
What do I do now? Thanks guys.
1987 Camaro 4bbl. (factory LG-4 car)
700R-4
2.73 open rear
[ 01-26-2005, 05:26 AM: Message edited by: BlueRebl ]
What is the quench height and dome configuration of the pistons? Is the 9.4:1 calculated using the longer stroke of the 383?
Where did you get factory spec's to set a 383? What dist are you using? You should set the total timing to about 32degs with the vacuum advance disconnected and the source plugged. Sounds like an HEI with way too much mechanical advance built into it.
...Dennis
"The '69, the '96 & the club"
he said all the electronic controls are in place, which would mean a small cap external HEI with no mechanical or vacuum advance of any kind. i bet the computer is still set to factory specs, which would call for more timing on a smog 305 than on a high strung 383 being choked by the stock emissions package.
is the knock sensor hooked up and working properly? maybe time for a custom chip.
355sb, vortec heads, HOT cam,T-10 tranny, 3.70 gears 16X8" IROC wheels. 12" Corvette brakes on the way.
see pics here http://community.webshots.com/user/novaderrik
<BLOCKQUOTE>quote:</font><HR>Originally posted by novaderrik:
<HR></BLOCKQUOTE>
There's no mention of electronic controls in the orig or any post in this thread until yours. Did you get something in e-mail we didn't see?
...Dennis
Dennis, I said that I have all the factory crap hooked up minus the EGR and the CAT.
Cable Bright
-'87 Camaro Z28
-'91 Caprice 9C1
-'70 El Camino 454 RAT
"....after all, people just want a normal life and a cool car....most people settle for the car."
Ok and I guess I missed the '87's description as well... That LG4 is a computer controled carb'd 305 and I belive you need an in line adapter (I think edlebrock may make them) that will adjust the computer for the new hardware you hooked it too. I think the 305 was rated at 165hp in '87, how does that compare to the new 383? I would think running without the cat and EGR would play havoc with the computer as well. Not meant as a lecture but you'll have a hard time passing visuals at your next smog check as well.
...Dennis
Just to add....on a stock LG4(or most engines with an EGR valve), an inop EGR valve would cause pinging as described...
Discussion Starter #10
<BLOCKQUOTE>quote:</font><HR>Originally posted by DjD:
<HR></BLOCKQUOTE>
The 383 runs awesome, the 305 doesn't hold a candle. I am guessing around 300HP/400TQ. It runs hard enough for cause my stock 700R-4 to slip under WOT during the 1-2 shift. Even so, I ran a 14.2 in the quarter with street tires and 2.73 open rear.
I do have a oil burning/smoking problem on accel and warm start-up (doesn't smoke when cold start-up) though. I am pretty sure its exhaust guides or seals. Guesses?
I planned on putting the EGR back on Monday (I'll report the results), and the CAT was plugged so I just hollowed it out for now. I plan on buying a high-flow unit before SMOG time. Just wondering, why would not having the CAT cause a problem with the ECU?
I do get a code 32 after a hard accel, then goes off after 20 seconds of normal driving. I also get that code on the Freeway about 70mph after I take my foot off the gas. Any ideas what's causing that?
Cable Bright
-'87 Camaro Z28
-'91 Caprice 9C1
[This message has been edited by BlueRebl (edited 09-13-2002).]
<BLOCKQUOTE>quote:</font><HR>Originally posted by onovakind67:
What is the quench height and dome configuration of the pistons? Is the 9.4:1 calculated using the longer stroke of the 383? <HR></BLOCKQUOTE>
This is a good point to bring up. According to Keith Black, you absolutely want to avoid a quench height between .060" and .120". In this range the quench area starts to act like it own combustion chamber and is a detonation nightmare. Above .120" there is no more quench area and the entire cylinder diameter acts like a single combustion chamber. Less than .060" and there will be a quench effect that actually cools parts of the combustion chamber and increases resistance to detonation (a very good thing).
9.4:1 is hard to get in a 383 unless you use a piston with a big dish or heads with large 76cc combustion chambers. Are you absolutely certain you are using 350 heads and not 305 heads? LG-4 engines are 305's and they have like 58cc combustion chambers - we're talking about 12:1 compression if you put these heads on a 383 with a flat top piston.
Have you done a cranking compression test yet? Anything above about 200 psi is likely to have detonation problems no matter how good or bad the factory ECU carb setup is working.
Discussion Starter #12
I know they are flat tops with 4 vf, and the heads are 76cc '92 Truck castings.
I used 5.7 rods.
Cable Bright
-'87 Camaro Z28
-'91 Caprice 9C1
I'm sure you changed Harmonic ballancer when you did the 383, did you change timing cover to match. There are two timing tab types, one at the 12:30 position and one at about 2:00 both require different marks on the ballancer, I've found them to be about 30^ apart. With the front pulley removed you'll be able to feel (maybe see) the keyway in the ballancer. if the timing on the ballancer is close to the keyway then the timing tab should be at the 2:00 position. if the mark is about .75", then the 12:30 position is correct.
Good luck
John
Another way to verrify would be to get a tdc checker (screws into plug hole) and verrify mark line up
Discussion Starter #14
[ 01-26-2005, 05:27 AM: Message edited by: BlueRebl ]
Has the outer ring on your balancer slipped by any chance. Have you verified that when the mark on the balancer is lined up with the 0 mark on the timing cover, the #1 piston is on TDC.
Discussion Starter #16
Bump.
[ 01-26-2005, 05:25 AM: Message edited by: BlueRebl ]
Discussion Starter #17
It ended up being that I was using an '80's timing cover with the '80's timing marks, then I was using a '70's 400 balancer which is suppose to use a '70's timing cover with the correct marks.
Live and learn.
sounds like the balancer is wrong type.
chevy had 2 different balancers with timing marks different from each other.
get some timing tape and your gonna have to redegree the cam etc.
or talk to the machine shop that did the work and ask them for suggestions.
1 - 19 of 19 Posts
