Well I have just rolled the 500 mile marker on my new 383 and I am left wondering... I just don't think that the power levels I was looking for are there. I wanted a 500hp 500tq street monster but the seat of the pants tells me it is not there. So I was wondering if the cam I chose might not be the best.
Here are the specs on the combo
383 10.5-1 comp
AFR 195 heads.. ported flow 278in 210 ex
Comp Magnum hydrolic Roller Cam #12-450-8
750 Holley HP series carb. (stock out of the box)
Air Gap intake.
Th 350 with Caon 3000 converter
12 bolt w/ 3.55 cogs
For a fuel system I ran -8 An from a sump in the tank
to the mech fuel pump. It is an Edelbrock 130 gph.
THe exhaust sys is a 1 3/4 long tube headders in to a 3.5 collector and 3 in system that has 40 series flows and an x-pipe.
Now the engine still needs some tuning.. it has a date with the dyno soon and only that will tell. If I had to guess I would say I am somewhere near 375- 400hp. THe engine runs and idels fine. It pulls hard to about 6300 and then the cam runs out. I have the rev kit so no valve float. I know that tuning can give allot so I am not gonna change anything till I get a good tune but I was just day dreaming here looking for more power. Also I need to get my fuel pressure gague hooked up so I can see if there is a pressure drop on WOT. I thought about a Comp cams XE series cam because of their more agressive ramp speeds. Ok below you will find the specs for the cam I have.
Here are the specs from the cam card.
Gross lift .560in 560 ex
duration at .006 Tappel Lift 286 in 286 ex
Valve timing INT 37* BTDC 69* ABDC
EXT 77* BBDC 29* ATDC
The cam has a 106 Intake centerline.
Intake Exhaust
Duration at .050 230 230
LSA 110*
Ok so what would the perfect cam be for my set up? THe only guide lines that I have is that it be a Hydrolic Roller.
Discussion Starter #2
no love? No one wnats to help??
Sounds like you need more duration. 230 @.50 for a 383 is not very large. A 245-250 @.50 would be more the ticket. Also, has the existing cam been degreed? If not, it could be advanced, causing you to run out of steam at 6300. My blown big block used a hydraulic roller: 612 I & E, 256 264 @.50, and peaked at 6200 RPM, 114 degree lobe center because of the blower. It was a great street cam, and would idle at 1000 RPMS all day, even with two honkin carbs. The cam should be heads up, and the duration increased IMO. You also want to be sure that your power loss is not due to fuel or lack thereof. Not sure if you have checked the jetting on the carb, but it could also be running lean on the top end at 6300. Make sure you have an adequate fuel pump. Alot of guys rebuild the engine and make it hot, and use the same fuel system. Just a thought.
