Ok so i finally took of those 14" super sport rims and polyglas tires and splurged for the 17.9" chrome hot wheels and 245/45/17" Tires front and back. I am having many issues with the tires rubbing/grinding! They seem to be rubbing on the frame just a little on both sides when you turn, and only on the right side inner footboard hub area with a sharp turn up the driveway or out on the road, the right is also hitting the screws of the chrome wheel well trim a little on a turn! Will spacers help at all with this, or going to 235 in the front which is only a 10mm diference? Can the suspension have anything to do with this? I have a 1969 Convertible RS/SS 350.
I've got 235/45/17s in front, 245/45/17s in back on my '68.
The fronts rub just a bit while turning and going down a driveway, just like yours. Mine were rubbing on some sheetmetal bolts around the back of the wheel opening.
I ground down the heads of the sheet metal bolts about 1/8" and rubbing reduced greatly. Then I found I had a bit too much caster on the alignment on one side and correcting that reduced it more. Rubbing is 99% gone. Good luck.
I have 235/45/17's on 17x8" wheels with 4.75" backspacing and they will rub the subframe if I turn lock to lock, I also have smooth alan heads for some of the fender bolts. Coupes seem to be able to get away with 245/45's easier than ragtops but the real key is the right width wheel and correct backspacing. I think you are going to have your work cut out for you if you have 17x9" wheels up front. They would require about 5.75" (which will cause all kinds of rubbing issues) back spacing or the wheel will stick outside the wheel well.
17x9 in the front? that is your problem right there (sorry to say). You should have an 8" in the front...at the most with a min. of 4.5 bs, even better is 4.875!
Good luck
