gotta 95 camaro thought the rotors needed to be turned, took the wheel off and the sway bar link is pushed back and the sway bar isnt flush with the eye, someone kno what i mean, my question does the bar it self need to be replaced also, i would appreciate any help> it shimmys bad slowen down on a exit ramp but when the brakes catch its fine.:confused:
you might be ok just replacing the endlinks, but you might also have a broken sway. take your time and inspect really well.
Also, take a little time to inspect the hubs, as well. Have you inspected the torque on your lugs? When was the last time you balanced the meats?
Also check for loose tie rods and ball joints, if nothing loose a good wheel alignment might be in order. Welcome to the team.
Jeff
Welcome to team camaro!! Sounds like the sway bar links are bad!!
