Hi everybody,just pulled my 69ss 396 out of storage for 12 years. paint and interoir look good. it now has a 468 big block with the original squareport heads and manifold. motors coming out & bone stock 396 is going in. is it possible to find a matching # block, guys bare with me Im new to this.
Welcome from So. Cal :cool:
Welcome.....
I think you mean a "Numbers correct" block....which would be, correct casting and possibly even correctly dated.....(and yes it is possible to find)
Because "Numbers Matching" around this place means "Born with" from the factory w/partial VIN stamped on block (if applicable)....
Would love to see some pics of your ride....post a few when you get a chance.
Dan
yes numbers correct block. My tag reads 12437nor 102039
st69
tr 712 72B
09D
what block and head #s should I be looking for?
Can you tell if this is a true ss big block car by the vin #? How do I post Pictures?
Thanks Joe
This link will tell you how to post pics:
http://www.67rs-ss.com/pictures/pictures.html
This link will bring you to Camaro Research Group....where you can find out anything & everything about 1st gen Camaro's...and will give you clues to identifying a real SS:
http://www.camaros.org/diffs69.shtml
The VIN will only tell you if It was a 6 or 8 cyl. from the factory...not the exact engine....
Also, be sure to use the "search function" on the toolbar above to search the archives....as you can find many answers to questions that have been discussed before.
Dan
