I have an optima in the trunk and will have a quick disconnect located outside the car that will push-off.
My questions pertain to the 3/8 bolts, are these just for the bottom of the tray?
I am going to purchase a billet mount for the battery but want to be sure it is legal, most attach the top of the tray with .1/4-20 bolts, but 3/8 could be used for bottom.
Also since an optima is a sealed gel battery does it require a battery box?
I did a search and didn't find any definite answers, and the local dragstrip told me to buy a NHRA rule book, which was a really big help!
Thanks, for any replies. SS
3/8ths bolts are to secure the battery not the tray. Safety dictates securing a potential 60 pound missile rather than the two pound tray. Don't forget the fire shield of 1/8th aluminum for rear tray and back of seat, and to vent battery box to out side of vehicle.
Larger Dave
NHRA book under Gen Specs states battery must be secured to the frame or frame structure using a min of 3/8 dia hardware.
If the plate is stuck between the battery & frame, then plate is secure.
Battery must be in a box vented to the outside.
I have mine bolted through the rear frame rail and nutted the plate to the floor. I have two 'cradles' the same shape as the frame rail used as washers. I then install battery and use a crossbar across the All-thread studs and nut them down. I used Nyloc nuts. I also sit the battery on wood and insulate the crossbar with a paint stick to prevent them from corroding.
Looks like Taylor makes an aluminum box which meets the firewall requirements.
Where did you plumb the vent?
Although I will still use a vent, the optima has no gases to expell being sealed gel battery, correct?
Thanks,SS.
