1 - 19 of 19 Posts
On my newly aquired 68, the venting system is not working. The blower motor works fine but no air flow out the vents, defroster or floor. There is a bit of air exiting, however slight, from the floor area but thats it. With the speed set to high, there is a bit of back draft on the vents themselves, as indicated by a lighter placed in front of them.
I'm assuming the kicker panels are for re-circ as there is alot of "vacuum" coming from there. It will almost suck them shut on high speed. The complete system looks to be new. The levers seem to move the flaps but I don't know if its moving enough.
Its almost as if the blower is in reverse, if that makes any sense.
Any help is appreciated.
Thanks,
Tommie
Re: No air flow out vents
Does the car have factory AC? if so the blower wires could be on backwards, and not short out.
Does the blower sound like it changes speed when going high to low speed.
I dont know if the heater box is the same or siilar tothe the 69...
If a 69 I would say that ewhen the 2 flaps inside where put in they where put in in the wrong seqence...
1st time I did it had me scratching my head hard till decided to remove and start from scratch...
The 2nd time yrs later, the moment I realised wasnt working right... i remembered...
Blamed it on the ma in law, she wasnt around so was safe...
She is a good stick really, just dont tell her that lol
Discussion Starter · #4 ·
No factory air. I have checked outside on the motor and black is grounded, red/orange goes to speed control. The fan works on all 3 speeds. Its real puzzling. Everything is new, wiring, motor, heater assembly, cables, etc. Hmmmmm.
Discussion Starter · #6 ·
There is no air coming out anywhere, that I can locate. Do the flaps actually stop all airflow or just direct it? Just wondering, is it possible for the fan to be wired backwards?
The two flaps/doors that are operated by the cables move. Really dont know if its enough but there should be SOME air somewhere?
It is pretty common for the defroster lever to break on the 68 heater control, have you checked that? The vents in the kick panels only let in outside air (or shut it off) as do the round vents on the lower right and left. I doubt you could make the fan run backwards.
Follow instructions... pull the damn heater box Out...you will see the flaps
they have to go in the right in the right order..If not you may get a little air flow out if the levers are in a given combination, all the rest you could F faster.
So you think the cables should move further and dont..
Its the bloody flaps put in the wrong order... not the cables.
It doesnt have ac so the blower wires cannot be on wrong, if they were, the fuse would blow.
Discussion Starter · #10 ·
I took everything possble out from underneath the dash to get a better view of the heater assembly. Everything as it's supposed to be, cables/doors were fully functional.
Then I took the ground off the blower motor and disconnected the power lead and swapped them. Fixed the problem.
Air now flows quite nicely... as it should.
Thanks for all the ideas and help!
You are saying you had the power to ground and ground to the power on the fan????
If that was the case, turn the fan on and the fuse will blow!!!
So that means you had no flow because of connctions wrong way, (and they are diff sized connection. banetts..1 fits the other doesnt) and a blown fuse....????
Something weird there.
It may be an aftermarket motor wired wrong internally if swapping wires made it work.
Discussion Starter · #13 ·
The whole package / heater assembly is aftermarket (new). The blower motor had 2 wires out the back side and being a DC motor, I checked both leads to verify 1 lead or the other was not internally grounded. Being okay there, I reversed the polarity to reverse the motor's direction. Bingo. With that being done, the only thing I could figure out is the wires got crossed during the manufacturing process... or the person was color blind?
Ok now that makes sense. It was bad to assume it was a stock system. But who would have known it was aftermarket?
It would have been nice, IF he said that in the first place, but I guess it is more fun to sens everyone on a guessing game.
Can't we be just nice to the new guy?
I am having the same problem on an all original system that worked fine. I replaced the my fan while I had the fenders off and I never touched anything under the dash. Until now I assumed that my cable came off the main "on" lever but I rarely ever use heat so it was going to be a winter project to fix the cable. I bench tested my aftermarket motor before install but I didn't look at what way it was suppose to turn. I wonder if I am having the same problem...
Tmax, so you switched positive for negative at the fan motor (to switch the polarity) and it worked without blowing a fuse?
Permanent magnet motor is not going to blow a fuse in either direction of rotation.
Tmax,
I see you posted on my old thread with the same problem. I have not fixed it yet but you may have helped me solve the problem. I'll try switching the wires around. Might be a batch of miswired motors from the factory. Pretty sure I got mine from Heartbeat City. You?
http://www.camaros.net/forums/showthread.php?t=183114
1 - 19 of 19 Posts
