I have a '67 RS/SS coupe and have lost my brake lights!
Here are the things I've done to try to find the culprit:
Checked the fuses - all seem ok
New brake light switch - tried one, no luck - returned it
Verified that running lights and turn signals light up at rear
I tried putting a jumper wire across the 2 receptacles that the brake light switch plugs into - nothing. Shouldn't that have lit them if everything was working?
I tested for power at the switch too - not sure if I did it right. I put one of the leads into one of the receptacles and grounded the other one and got 12 volts.
Any ideas?
Thank you!
Any ideas?
Thank you!
