Bought 73 Camaro converted from auto to 6 speed. No brake switch mounted in orig bracket. Have blinkers front and rear. Have running lights. Need to know how to wire new brake switch.
If this car has original wiring harness still there should be a two wire plug with an orange and a white I think. Orange is battery ( hot all the time) and white goes to Turn signal switch, When you put on the T/S the brake light signal is interrupted for that side.That is why the circuit goes thru the T/S switch. Every thing else in the circuit is good because the T/S work.
Jeff
