1 - 2 of 2 Posts
Wanted to start from scratch for an intermmitent starting prob. After repacing both battery cables the car will not crank...no headlights no nothing. What in the heck did I screw up? I went from a car that would turn over to one that wont...even with a new battery which reads 12volts. 1968 camro...327. The fuses in the fuse box are ok...are there mres fuses somewhere else?
Gary
There's a wire that goes from the + battery terminal to a terminal block and then over to the horn relay. This wire supplies power to everything inside the car; lights, ign. switch, etc. Find it and hook it back up.
'69 RS Camaro
355 5-speed 4.11
1 - 2 of 2 Posts
