1 - 2 of 2 Posts
I installed a new wiring harness and everything was working great. Now the radio doesn't work but everything else does. I check the power at the fuse block, no power. How does the fuse block get power for the radio fuse, what would be the next location to check for power.
thanks for the info.
Welcome, John.
No mention of year, but should be al the same.
Radio has its own fuse, but, has the same ign/acc power buss bar as heater blower and wiper motor.
If those two accessories work, then may be a problem with the fuse panel.
If not, then check 12GA brown wire from Ign switch, and check radio ground at the inst panel where mounted.
1 - 2 of 2 Posts
