:confused: I would like to say thanks to anybody that takes the time to read this.
I have a 1988 2.8 . I pulled in to my friends house and when I came back out it wouldnt start . it turns over but no spark to plugs. I have changed everything except the pickup in the distributor, and I was wondering how to do that. if any body can help that would be great.
If that engine has a crank position sensor, check it using the diagnostic procedure in a haynes manual or similar. Ignition, pickup assembly can also be checked. Both test similarly using a DVM. The module(s) should have power and ground. With the meter set to the DC scale, you should see a voltage signal when the engine is cranking.
