Most heads have one port. Do you have a sender in each head? driver side head is between the first two spark plugs Passenger side will be between the last two spark plugs;Well my thought was it is a oil port but wanted to confirm, thanks
I have the OP gauge plumbed into the rear port behind china wall on the 327.
Was looking for a second water port as my heads don't have one so currently have the gauge "T" to the one port on my intake manifold with my dash light sender
Jeff,Most heads have one port. Do you have a sender in each head? driver side head is between the first two spark plugs Passenger side will be between the last two spark plugs;
Jeff
https://www.partsgeek.com/gbproduct...HPD4q0bxrPPn9OKSsKUs6qQ7FjstYZxkaAnRrEALw_wcBIf you are not too concerned with original appearance get a thermostat housing with a fitting in it. They also make them with two.
yeah no ports on the heads.Jeff,
A lot of the early heads did not have water temp ports. Just did a 327 for a Vette that did not have them.
OP,
completely forgot about those heads. my first car was a 64 chevy II that a previous owner had transpanted a 327 4 bb from an Impala into. Next car was a 69 Camaro 307 with accessory hoes in the heads. I quickly forgot about those old double hump heads from that 327.Jeff,
OP,
