Today I replaced my original GM console fuel gauge because it wasn't damping the needle movement when fuel "sloshes" around in the tank. I used an OER replacement. In comparison the OER has internal resistors so you don't use an external one. Just for the sake of it, I measured the external resistor and it measures about 85 ohms. When I opened the package with OER gauge, I noticed the needle positioned up to "max full". It appears the default position is "max full" when ignition power is turned off. As soon as you turn the ignition on to power it, the needle goes where I would expect it to be. I haven't run a tank of gas through yet to confirm it's accuracy but It does dampen the needle movement like it's supposed to. Can anybody using one of these OER gauges confirm theirs also works like this?
