1 - 20 of 36 Posts
First, thanks for everyone here for all the help, it has been great.
Now, the disaster. I have plowed a lot of cash and time into my 67 RS convertible...way too much in some respects. New crate 350/385, headers, rebuilt th400, serpentine setup w/new PS pump, alternator, etc.
I took it down to Dick Guldstrand's shop to get the suspension upgraded/fixed and...he reports back to me that the thing is a RUSTBUCKET that might not even be repairable.
Ouch. That hurts. So here are a couple of questions:
1) Is it possible to have so much rust damage to the frame/subframe/pans that it really truly cant be repaired?
2) Is that type of work (serious rust repair / metalwork ) super expensive?
3) Should I be at all pissed off that the shop that did the engine / tranny / exhaust swap and had it up on the lift never said diddly about any kind of rust problem?
Thanks for any advice. I need it.
The first gen convertibles were known for these issues and problems. I looked hard and long for a car before finding my wife's 69. It had some rust, but not to the extent that you are describing.
First, the convertibles are very easy to disassembly yourself and the pans can be replaced and there is a lot of metal available for such, as well as the front and rear clips can be repaired, but it's only money. You have to have good mounting surfaces for both the frame and body for a good handling and ride, otherwise it will be floppy as a rag!
I would not blame the guys who did the rest of the work for telling you bad news.
STEVE JACK
ConceptOne Pulleys and Brackets
Techical forum/links at www.inccn.net/techforum.htm
[This message has been edited by HOTRODSRJ (edited 04-22-2002).]
That sucks, but how much rust are we talking about here, be more specific.
is it at home, give me an email, I'll come by and tell you what i think(at least one other opinion)
http://hometown.aol.com/autumnnatalie/index.html
[This message has been edited by cody (edited 04-22-2002).]
The rear subframe rails can be replaced pretty easily, as can all of the floors. I would imagine that if there are parts of the body that make direct contact with the front subframe that are just rusted right out, now that would be a big problem. I doubt the front frame is shot, but the rear rails commonly rust away. There are other parts of the body that rust away to nothing that are critical but with the right replacement part and a knowledgable welder, can be replaced.
I guess it depends on what areas of the car they actually meant by 'rustbucket'.
Joe
WCA Member
[email protected]
[email protected]
'69 wallet crusher
http://photos.yahoo.com/hwystarjoe
I did a lot of searching and saw a lot of rusted out cars before I got mine. I talked with most of the resto shops here and asked the same question, when is a car beyond repair? They pretty much told me that anything could be fixed it was just a matter of how much $$$. I really wouldn`t be too concerned with a suspension shop telling me my car was rusted out. How often do they see 1st generation cars? They are probably used to seeing newer cars. I am not slamming the shop, I just wouldn`t be overly concerned. How much rust are you talking about?
It can all be repaired. I, too, found that my car was very rotted. Although I can weld, I felt it was beyond my scope and found a fellow to do the work. I bought the full pans, made in US, that run from toeboard to rear seat back seam and had the entire area replaced. This gave me a new base, including the tranny tunnel. Also replaced was the rocker inners and parts of the internal rocker reinforcements. There was other repairs and now I'm back on track. A lot of $ but I don't plan on getting rid of the car.
Rick Dorion
69 RS Conv,355,M20,4.10's and I don't worry about stone chips ( yet ).
Discussion Starter · #8 ·
Thanks everyone. Cody, the car is in Burbank now, I drove it down last weekend to take to the shop. OK, well, the rusted out parts are the floorpans and the part of the body where the front subframe bolts on (the rear area is bad too, but not totally eaten away like the front). In the front, those big bolts just flop around. There is also rust in the trunk. I took some pictures and will upload them when I get back to the bay area. I am glad to hear that it can be repaired. I am good at soldering electrical things, but never welded and would leave that to professionals. Thanks again, I will get the pictures up and if anyone knows a good source for metal, please let me know!
Guldstrand probably saw firstgen Camaros before any of us did. He reportedly won the first road race a Camaro ever won.
What did they say about what you could do about the rust?
David
David's Motorsports page
First Gen Suspension Page
Personally, I don't like rust damage repair. Tons of work and very expensive if your not capable of doing it your self. Here's and idea. Since you have basically everything else other than a good, rust free body why not find a "shell/body". Basically swap everything you have over to the rust free shell/body. Most likely will save big money and have parts left over to sell to your friends. Finding a suitable body might be hard if San Fran but down here in L.A. they are around. That's considering that you are willing to use a coupe instead of a convertable. Dick knows what he's talking about. If he says the modifications would go wasted on your car due to rust damage then I'd trust him. Heck, does not sound safe to drive period.
Joseph
Discussion Starter · #11 ·
Dick Guldstrand is very, very wise and super friendly and fair. I agree, the best thing to do would be to find a donor car. I am going to leave the car in LA until I find one. I may sell it to a body guy after I take out the motor instead of parting it out. I don't want to deal with the rust. Dick had a guy look at it and it will cost $4K just to get it roadworthy...not even to fix all the rust. He suggested that might not be the best thing to do.
This was a very very expensive lesson. Well, this was my first vintage car so I won't make that mistake again.
Oh, when I was in there, they were just finishing up restoral of a Yenko Nova that the owner put a 502/502 into. The headers were on but the exhaust wasn't connected. It sounded like a dragster.
Well, time to look for a new camaro. I guess the convertibles were notoriously rusty, so I will look for a coupe. www.recycler.com i guess...
I feel your pain! I too was told that my car was beyond repair "Don't Bother" But, I made the committment to do whatever it takes, no matter how much it costs...and believe me, it costs ALOT!!!!! Look at the picture on the dolly, car needed full floors, frame rails, Quarters and 1 door, complete trunk, fillers and extensions,inner and outer wheelhouses perch boxes were toast, as were the shock mounts, and the entire area under the rear seatback support, rockers needed repair as well. But it is worth the time, effort and money spent.
If you don't have an sentimental attachment to the car (I do)..buy a shell, if you do..Get a home equity loan!!
Good luck with your decision.
[This message has been edited by CrossRamZ11 (edited 04-24-2002).]
Wow!
Rick Dorion
Discussion Starter · #16 ·
I woke up this morning with a different attitude. I am saving this Camaro, cost be damned. I plunked down a deposit and the metal guy is going to start work tomorrow. Seeing crossram's pictures sure did help me feel good about my decision. Afterward, I will still have to do paint, interior, top, RS headlight motors, and stereo.
My 67 ragtop will not go gently into that good night.
Ok, so it is purple and has a white top and a blue interior that someone spraypainted black and enough rust for a...a...a big pile o' rust and 'Judy' painted on the quarters. But it's MINE and I'm going to get it into shape, dammit, one stinkin part at a time.
thanks for all the help. the rust pictures are at http://www.bignet.com/camaro/rust.htm
[This message has been edited by chevyoldman (edited 04-24-2002).]
I personally am glad another convertible is not going to be parted out or destroyed. I'm on the same path. Good luck and post some pics occassionally.
Rick Dorion
jeez, is that it???
mine is much worse and i'm not going down yet. do your doors open and shut properly?
btw, is that a license plate in the driver's floor board?
tybor
It's great that your going to do it up.
My car "looks" good, but the truth is, though you can't see through the floor boards, they are thin. Very thin. That fact remains and that I'll need major floor pan work before the paint goes on.
Net net: Even a car that looks solid, chances are it isn't and will go through the same pain as you.
I was at the shop I'm going to use for the work this winter, just yesterday. Paint strip, lead removed, rust abated, Detroit Speed Sub Frame connectors welded in, sub frame blasted and painted, Energy Suspension or PST bushings installed, paint, 2 clear coats and sanded, 2 clear coats and buffed.
We figured on 7 to 11.
This is cheap when you consider a new C5 Vette will run you 50K. Our cars have so much more personality.
R.O.
1 - 20 of 36 Posts
