I'm using an ARP oil pump stud instead of a bolt. The proper bolt torque is 65 ft/lbs. Should I use this same torque on the stud? ARP lists proper torque on a 3/8" 170,000 psi stud as 45-50 ft/lbs and I don't want to exceed the stud's yield strength.
Thanks. -Neil
Thanks. -Neil
