1 - 2 of 2 Posts
Ok I found where the hazard flasher goes. That's under my dash plugged into this little box. But that's only the hazard. There is also a plus for the horn and the choke. There is one plug unused and there isn't even any wiring don't too it. That one says T/S which I beliefe stands for turn signal. But there is nothing in it or any wires. Can someone please tell me what the TURN SIGNAL FLASHER Looks like on a 82 camaro. Its NOT the silver round flasher. That is hazard only. Got any help?
sorry to say but its more than likely another silver round flasher, should look almost exactly the same but normally located away from the hazard flasher and mounted differently (they are almost never in the same connector on chevy cars)
if your hazard flasher is not mounted in the fuse box than is the turn signal flasher in there?
you should get a shop manual like a chiltons or something that will help you find the flasher and have pictures
1 - 2 of 2 Posts
