1 - 2 of 2 Posts
My car is back from the shop, but not completely running because of some wiring issues. I have the engine harness in, but I guess I need the lamp harness to maintain voltage, but what other wiring things will I need to keep the engine running. I have the dash harness, engine harness, all the battery lines. The actual engine is all set...what else?
Lamp Harness
Voltage Regulator
Tim
engine really only needs the power to the coil to maintain the spark to run. Make sure there is 12v coming to the resistor coil, which then drops voltage to roughly 6v to the + term of the coil. Verify that your ignition sw is working and suppying power back to the fuse block, the ign fuse is good and that the resiter coil is good. As long as all that is good and you have 12v coming from the starter to the + term at cranking you should be ok.
1 - 2 of 2 Posts
