" "You probably have a blown wheel cylinder.
You were spot on. But you missed the other 2 blown wheel cylinders for a total of 3 blown cylinders. I have no idea how I was driving this thing. After I spent this weekend searching down parts, I repaired everything and she's back on the road.
I think I want to eventually change all of those line. And HOLY CRAP the way the front wheel cylinder bleeders are positioned (slanted at an angle against the car) it's almost impossible to bleed them. I actually ended up bending a 9mm wrench to contour it to the way I needed it to be. There must be a special tool but I didn't have it and just made my own.While you are fixing the wheel cylinders, you might want to check the original front to rear line. If original, it may leak by the line/rear hose junction. The line loop (looks like a drain trap) must hold more water and road salt than the rest of the line and rusts faster.
Which bowl controls the front brakes and which controls the back brakes? This should help me narrow the problem down. 4 drum original brakes. Master cylinder looks replaced but with an OER part. I am getting spongy brakes. And one other question. Is the gasket for the MC lid supposed to be flat or should they basically have 2 (cones for lack of a better term) sticking down into the bowls?
If your loosing brake fluid , you definitely have a leak number 1, and 2, if nothing more than for much better braking and safety reasons, I’d put disc brakes on the front . As for the master cylinder, I believe the front reservoir is for the front brakes and a dual master cylinder has 2 cones inside that drop down like an accordion to fill the void from lack of brake fluid. Either way, you have a leak!Which bowl controls the front brakes and which controls the back brakes? This should help me narrow the problem down. 4 drum original brakes. Master cylinder looks replaced but with an OER part. I am getting spongy brakes. And one other question. Is the gasket for the MC lid supposed to be flat or should they basically have 2 (cones for lack of a better term) sticking down into the bowls?
