my 95 3.4L seems to run pretty good
but im only getting 16 MPG and i dont
hot rod it, i mostly cruise at less than
2000 PRM and rarely get on it at all.
are there possibly any sensors/etc that i should
change to improve my mileage?
any other suggestions? ...zimmy
How many miles is on it? Friend of mine had same prob and had a clogged cat and replaced 02 sensors and straightened it out. Also try cleaning air filter. It's not breathing like it's suppose to.
it has almost 118000 on it.....
the air filter is clean.
replacing the 02 sensors seems like
a good idea....i want to replace "all"
of the sensors on the motor, but im
a little broke right now so im tring to
prioritize till i get some cash .....z
Wow, 16 mpg is terrible for a six. I like the O2 sensor and catalytic converter replacement idea. If your state has vehicle emissions, you might have them hook the car up and do a read out and see if everything is good. ...... Oh, btw, you could try disconnecting the battery for a while, then hooking it back up. This should cause the computer to relearn everything and it 'might' run better.
i changed the 02 sensors yesterday...seemed to run a little better till today when it decided not to start. z
leaking fuel pressure regulator?
