I will do some more searches after posting, but help is needed. Upon deciding to keep the car, I thought I'd start cleaning up the underside. Looked pretty good (I thought) when I brought it home so I wasn't too concerned. Low and behold, when we started peeling away layers of coating, we found poor patch jobs. Looks like the P.O. put new floor pans over the old ones, from the underside, and then put some kind of sheet metal over those. When he got done, he coated the whole underside with a tar equivilant. YUCK! It took an air hammer to get thru the 2 layers he added which left me the original pans that look like swiss cheese.
My question is this...the tunnel looks good, so far as do the pans under the rear seat. Can I replace the pans using the LH and RH sections I see that are about 60" long? I can't really afford to use the 1pc pan. What else do I have to consider when replacing pans? This wasn't part of the plan when I got this thing....
