1 - 13 of 13 Posts
Do repro protect-o-plates come attached to the orrigonal warenty info and paperwork? I am wondering this because the one i found with my z has never been used and is still stuck somehow with the back twards the reader to the orrigonal paperwork. Is this a extremely rare find or not. I know orrig. '-o-'s are rare. info if possible please
Joel
1969 Z28
Should be glued to the booklet, last inside page. Everything reads in mirror image. It should have the origonal owners name on it.
Discussion Starter · #4 ·
I would love to post htem right now, however, the car is 120 miles away from me and the least time i saw it, i didn't get all the numbers. (short time) However, I'm going back this weekend and I should be able to post them soon.
Discussion Starter · #6 ·
yeah, no problem. I think I have them, but I need to double check them when I get the car in the light. Out of curiosity, why are you interested in my #'s?
Joel
1969 Z28
Kurt is a member of the CRG - Camaro Research Group....they are putting together Registries of all first gen cars....
Hope you don't mind me answering for you Kurt......
Steve McCorry - Central Ohio Camaro Club
'69 Camaro RS/SS-350 - Daytona Yellow
'95 Camaro Z-28 - Sebring Silver
click here to see my car ---> www.mindspring.com/~mccorry
No problem Steve. I don't always watch this topic grouping very closely.
Joel,
We realized that a lot of info could be gained from recording/ documenting 1st gen cars. We have about 2700 vehicles in our database and it is one of the sources of data that fuel our research. Our data submission page http://www.camaros.org/researchdata.shtml has more info, but basically, your data is kept confidentioal and is not distributed. The more complete the data is, the better our research results. And record mundane details like wheel codes and booster dates. I maintain and add the data (and spend many hours doing so). My other project has been making a broadcast sheet decoder.
All gratis.
Kurt S.
www.camaros.org
Discussion Starter · #9 ·
I got the #'s!!
Here they are.
Feel free to decode them. I did not post the orrigonal owner or address for obvious reasons. Our family has known him and the car for years and I'm sure he doesn't want us posting his address.
Protect-O-Plate
124379N687273 H
VO911DZ BU0911G 9
P9H30 1 3 (BOWTIE)
NAME
ADDRESS
ADDRESS
11/3/69 480 (could be 460??)
Trim Tag (correct termanoligy??)
BODY BY FISHER
ST69 1237 NOR126457 BDY
TR715 71 71 PNT
09C X77D80
Joel
1969 Z28
Protect-O-Plate
124379N687273 - Model Identification
12437 - V-8 Camaro Coupe
9 - 1969
N - Norwood
687273 - Sequential Body Number
Camaro build sequence numbers began at 500001 in 1969
H - Carburetor Source Code-Plant
H - Holley
VO911DZ - Engine Production Code Number Explanation
V - Flint Motor
09 - Month (Sept)
11 - Day (11th)
DZ - 302 Z/28
BU0911G 9 - Rear Axle Code
BU - 3.73 posi
09 - Month (Sept)
11 - Day (11th)
G - Chevrolet Gear and Axle
not sure about the 9?
P9H30 - Transmission Code
P - Muncie four-speed
9 - Model Year (1969)
H - August
30 - Day of Month
1 3 (BOWTIE)
depends on where it is on the plate go to: http://holisticpage.com/camaro/parts_fs.htm
to see location, but probably 1 - N40 Power Steering and 3 is the radio option (am, am/fm, am/fm sts)
NAME
ADDRESS
ADDRESS
date sold? not sure.
Trim Tag
BODY BY FISHER
TR715 71 71 PNT
09C X77D80
check your 1237, probably 12437
69 - Model Year = 1969
1 - General Motors Division - 1 = Chevrolet Motor Division
2 - Car Series - 2 = Camaro
37 - Body Style - 37 = coupe (67=convertible)
NOR - Assembly Plant - N=Norwood, Ohio (L=Los Angeles)
126457 - Norwood body number assigned to that body by the Fisher Body plant. It helps track the car through the plant. This number will never match the VIN.
715 - Interior Trim Code - Blue standard
71 71 - Body Color Code - LeMans Blue, no vinyl top
09C - Build Date - 09 = Sept., C = 3rd week of month, since this is a 687273 it was built in 1969 (late in the production, rather than 1968)
X77D80- Style Trim Group
X77 - Base car with Special Performance Equipment(Z28)
D80 - Air Spoiler Equipment (when used - not all cars built with spoilers were coded)
think all this info is close, if i'm wrong, i'm sure someone will correct me. sounds like you have a very nice blue z/28 with a lot of documentation.
To see a pic of my car, click here... pages.prodigy.net/mtbmtb/rf396ss.jpg
The 9 on the POP after the axle code is the month. The 1 and 3 at the end are probably power disc brakes.
Or does it have power steering?
All the drivetrain codes should match the #'s on the POP. The # on the trans should also have a letter after it indicating M20,21, or 22. The rearend code will have a # after it for the shift.
Does it have a tach (with or without guages)?
Thanks.
Nice to have documentation!!
Kurt S.
www.camaros.org
67 trim tag should have 3L - RPO Z22, Rally Sport Equipment on the last or next to the last line.
1 - 13 of 13 Posts
