1 - 19 of 19 Posts
Hi Folks,
We are looking for some ProTouring Camaros that will be on the show-n-go circuit next year that are looking to make an upgrade to our Paddle Shifted A-41 Overdrive automatic. This transmission will replace Turbo 350/400, 700R4/200R4, 4L60, 4L80, 4L80E.
The key feature with our product is the fact that we have added engine braking to 1st, 2nd and 3rd gears, so the free-wheeling is gone (except in 4th). The result is a connected feeling and control just like a manual transmission, but with the convenience of an automatic. And this is a Hydramatic automatic, not an automated manual transmission.
The paddle shifter is easy to wire up - just horn power and that it. It's wireless connection to the receiver unit, which plugs up to our controller. And the paddle shifter has a nice large bright LED display that allows you to display from more than a dozen data points to monitor - vehicle speed, engine rpm, throttle position, coolant temp, turbine speed, torque converter lockup, etc.
When you going into paddle shift mode, you just switch the Dual Mode switch from Cruise to High Performance, put the gear selector in OD, then you have full manual control over every gear 1st through 4th. In fact, just like a manual, you have to upshift and downshift with the paddles, or you will remain in that gear.
For track courses, this is ideal. You can keep your hands on the wheel, and be in full control of what gear your are in. With the engine braking and no free-wheeling, you can get the most out of your car and driving skill.
You can learn more about this transmission here.
Also, here is a raw
of my ProTouring '71 Cuda with this transmission.
We do these as complete kits, there is no cutting whatsoever, and I'd like to offer some special discounts to those of you willing to help us promote the product at your shows.
No salesman speak here ... this transmission is simply incredible.
Cool stuff. This automatic transmission technoligy has come a long way. Last year I rode in a Twist Machine Paddle shifted 4L65 with the muscle drive converter (engine braking converter) and it was awesome. I was so impressed I will be putting a Twist Machine / Bowler Transmission 4L80E version of this set up in my personal street racer.
...4L65 with the muscle drive converter (engine braking converter) and it was awesome...
Prodigy Customs,
thanks.
The "engine braking converter" you mention is not something we are using. Our transmission actually has modified hydraulics and electronics, along with changes to the sprag clutches, rollers, etc. You might want to check with Mark on that e/b converter.
What is the retail on a Bowler 450HP/450TQ setup with a Twist machine setup, all in with crossmember, driveshaft, Camaro Horseshoe shifter gate and lens, trans cooler, lines, wiring harness, computer, hardware, torque converter and flex plate? I know our product is a lot less, but I'd like to hear from a Bowler dealer like yourself.
The TM stuff is cool, but they don't have the display. Here's a picture of the my customer's car with our A-41 and the Twist Machine shifter. It's a bit more flashy but very cool also.
I don't think it is TCI, on my box it says CompuShift by HGM:
http://www.compushift.com/products/compushift
I don't think it is a repackaged from another vendor but I don't know for sure. Maybe Steve from Twist Machine will pop in and answer.
The controller pictured is not a Compushift unit.
It looks like a PCS (SP) unit repackaged. Plus it shows software page & you need a laptop to program it,which Compushift you do not need to use a laptop.
http://www.powertraincontrolsolutions.com/content-4.html
Here is the TCI
http://cgi.ebay.com/ebaymotors/TCI-377500-Automatic-Transmission-Controllers-TCU-Syst_W0QQcmdZViewItemQQ_trkparmsZ72Q3a1205Q7c66Q3a2Q7c65Q3a12Q7c39Q3a1Q7c240Q3a1318Q7c301Q3a1Q7c293Q3a1Q7c294Q3a50QQ_trksidZp3286Q2ec0Q2em14QQhashZitem370119001994QQitemZ370119001994QQptZMotorsQ5fCarQ5fTruckQ5fPartsQ5fAccessories
MBHD
Discussion Starter #8
:D
Our product is a proprietary unit made for us by PCS, since 2006. TCI also changed over to PCS, sometime in 2007 I think. While the packaging looks similar, they are not interchangeable.
Our unit has additional features, like the Dual Mode Cruise/Performance switch. It also has a TPS Setup Wizard to make the TPS setup foolproof and easy.
All of our units are preprogrammed and don't require a laptop unless the TPS Setup Wizard is used. While we can offer a hardware handheld, it doesn't make financial sense since most people have a computer, even a desktop, and can hook up to our controller via USB or Serial cable.
Really, laptops are so cheap now used (around $100-300), and having one allows easy access to all of the really cool features of our product like data logging, real time playback, dashboard screen, part throttle, full throttle curves, etc. You can make adjustments at the track, test, adjust, etc. :cool:
Can you shift into any gear any time or will the computer over ride the shifts a times? For example on down shifts at low rpm will it stay in 3rd or 4th gear untill shifted manually?
Discussion Starter #11
just when it's cool to have a 5 - 6 speed, you guys come along and kick our asses.... awesome work! Just how pricey is this "kit"?
ls427ss,
Thanks for the nudge - someone has to keep setting the bar higher, right? :)
As a sponsor, I'd defer not to post prices in the tech forums. But if you can PM me I can give you the full details, and you can be the judge on it's affordability.
Discussion Starter #12
Eric1967,
When you flip the Dual Mode switch into High Performance mode, this will put the transmission in full Manual control. It will not upshift or downshift without your paddle touch. So, you what ever gear you paddle-up or paddle-down - 1st, 2nd, 3rd or 4th - what ever - it will stay in that gear until you tell it to shift by bumping the + or - paddle.
When you flip the Dual Mode switch back to Cruise mode, the transmission will be in full auto mode. You can bump the + or - paddle, and the transmission will not shift until its parameters tell it to. In other words, the paddle has no operation in Cruise mode.
Does this answer the question? If not please ask more ... that's what I'm here for.:thumbsup:
Shafi, just to get a lil more specific...
Automatics (stockers) I have dealt with had safety's. As an example, even a 1968 model T350 just plain will not downshift to first at 75 mph no matter what I do with the gearshift. Modern e model transmissions won't shift into reverse when the car is moving.
A race manual valve body trans does not have any safeguards.
Does the a41 still have the safeguards when in performance mode?
And in cruise mode, are the paddles completely dead, you have to use the horseshoe shifter?
Prodigy Customs,
Prodigy Customs,
FYI, I am a Bowler dealer but do not really pursue retail sales, but do use their units in our shop projects. I am happy to sell a kit to someone even i they are not having a car built in our shop, but usually refer those sales straight to Bowler. I am not a Twist Machine dealer, however that conversation has happened and maybe someday we will be a dealer. I did however use one of the very first paddle shifters for the aftermarket and debut the that paddle shifter at SEMA in 2005 in the Billy Goat for Twist Machine as their feature vehicle.
As for pricing, as you know there are so many variables in each kit it is hard to say what cost is. I will be happy to post Bowler pricing and specs if I know exactly what we are doing. I can tell you on the front end Bowler has a tendency to over build everything so it may very well cost a bit more then your package, I know Bowler is diligent in their process and build and dyno every unit in house. You may do the same, I do not know.
So I guess since you asked me I can ask you how much your kits are. But it looks like you may not want to publish any pricing. We can publish pricing in the sponsors forum here and it is encouraged.
I may very well be interested in your product and being a dealer for it if it is equal apples to apples and less money then the Bowler / Twist product. I would be willing to do the same thing for you guys I do for them and torture test one of your units like I have for Twist and Bowler in the past. We are rough on stuff. My dad always told me I could wreck a ball of steel. LOL!
Discussion Starter #15 (Edited)
JimM,
Great questions, and I received some related ones from ls427ss (Larry) also. So, I'd like to address all of these with the answers I gave to Larry, plus the additional ones from you.
1) QUESTION: Does the engine braking work like a turbo 350/400 or more direct line a standard trans. The light speed shifting possibilities both up & down are interesting to say the least.
ANSWER: the engine braking would be similar to turbo 350/400 when you manual shift it through the gears. Notice the transmission performs differently when you manually shift it versus putting it in D and running it up the gears.
2) QUESTION: a) Does it have enough engine braking to lock the tires downshifting if you shift under road racing conditions @ high RPM or just fooling around? - AND- b) Does the a41 still have the safeguards when in performance mode?
ANSWER: a) oh yes, *IF*you were to change the parameters. Basically the computer looks at the redline we (or you) program it to be, then does a calculation to see if your commanded downshift will maintain the RPM within that max limit. So, if you run the redline limit up to say 10,000 rpm, you might be able to command the transmission to downshift and loose control of the car. b) in Cruise/Normal mode, the transmission is full controlled by the computer, and will run to the limits preset by us (or you)
3) QUESTION: In cruise mode, are the paddles completely dead, you have to use the horseshoe shifter?
ANSWER: The paddle shifter display will always show the gear you are in, PLUS the additional multifunction display you select (if any; if no additional parameter selected, only the engaged gear will show). Now this is a very important function to understand: The Paddle Shifter only controls up and down shifting while the gear lever is positioned to the OD position. The Paddle Shifter, under no circumstances, will shift you out of Park, to Reverse, Neutral or Drive. You must do that manually.
I think that answers your's and Larry's questions. If not, please reply here and I'll explain more detail.
Here's a question to you folks:
What do you think about me doing an in-car video where I explain the operation in car, plus do some driving with the camera on the paddle shifter & dash? I have the video/audio equipment, and was thinking this might be a good way to explain it to others. Like a virtual demo, per se.
Discussion Starter #16 (Edited)
Hi Frank,
Yes, all of our units are 100% dyno load tested WITH the torque converter - very important - and checked to a stringent standard. They are overbuilt. For example on the Mopar side, we have guys running 528ci HEMI putting out over 700 HP and 700 FT-LB torque, and not breaking them. But we set the advertised rating at 650 HP / 650 FT-LB with an internal safety margin.
Please contact me off line to my email address or by phone and we can discuss more the this at that time. Thanks,
Shafi
Discussion Starter #19
Hi Folks,
Larry ls427ss made some good recommendations for the in-car video, so I will try to make it happen over the holidays (weather permitting).
If there is anything you want to see in particular, post it up here.:beers:
Shafi
1 - 19 of 19 Posts
