1 - 2 of 2 Posts
classic industries sells OEM, an acrylic laquer paint for hard interior pieces,my local auto paint store carries acrylic enamel,can i use the enamel to paint my interior pieces(kick panels,pillar posts,dash,sail panels,etc.) they can match any color ,,any info would be great,thanx...
70SScamaro,ground up restification,350SB.
I've used Ditzler Vinyl Dye sprayed with a gun to re-do interiors, on both soft trim and hard plastic. You need to be sure the hard plastic parts are cleaned with soap and water, then wiped with a little lacquer thinner before spraying. I never tried just enamel. Ask your guy about the vinyl dye.
1 - 2 of 2 Posts
